Connecting to my local desktop
How do I connect to my local desktop to work on my tune? I am using an ECUGN with a DD-efi prodash.
Re: Connecting to my local desktop
Are you looking to connect wirelessly?
Yes i'm also Trying to figure out how to connect wirelessly. I can't figure it out
Yes looking to connect wirelessly. I have a DDEFI dash and an ECUGN. dash is connected to ecu. I want to use my desktop remotely if that is possible to look at the tune and make changes. It's just more comfortable to sit at a desk to look. I need to set up the wifi connection and connect to the ecu/dash.
If you are running TS Dash on your dash, you can use Dash Echo from your desktop.
But, currently the DDEFI dash is still using TS.
So, you can use a remote in software like VNC, Anydesk, Team Viewer, etc..
