TS Dash Pi GPIO help
I purchased Tuner Studio MS and TS Dash Pro with the intentions of creating a digital dash for my race boat. Boat is powered with a 632 BBC carb and distributor with ignition by a MSD box. I want to be able to read 5v sensor voltages (stepped down to 3.3v) on a raspberry Pi 4 GPIO pin. I thought that TS dash could read the voltages but it appears that it can only use digital in and out (high or low). Any solution for tuner studio to read analog voltages via the raspberry Pi? I am aware that I could purchase a MS3 but that would be a waste to run a dash. Possible cheaper controller that can communicate with tuner studio that reads analog signals? Any guidance or direction would be much appreciated. DASH image for bonus points.
Re: TS Dash Pi GPIO help
It seems you would need a MicroSquirt or perhaps an IOExtender.
Hello
iam looking for a solution to get oil press to my ts dash. are there plans to implement analog gpio to ts dash?
i dont know why there are 30ish digital io. i cant imagine a scenario where someone needs that much digial io.
thanks
tim
thanks
tim
So, in order to have analog i/o, you have to have pins with an ADC chip backing them. Iirc, the pi only has two such pins. The pico (a $5 microprocessor) has 4 iirc. So wiring the pi directly for analog sensors isn't going to work the greatest. I suppose some firmware for the pico can be written to use it as a megasquirt in the eyes of tsdash, but you'd need some level shifters (just some mosfets and resistors really) to get any pulse signals that don't use the picos 3.3v rail (like coil - rpm signals). Temp, TPS, ect, can all just use the 3.3v rail as they're basically just variable resistors acting as a self contained voltage divider (at least in the case of 3 wire, 2 wire would need an external resistor I think). VSS can be handled on the 3.3v rail as well as it's just a ppm signal. It's all just a bit of a headache, but I can toss together some example code this weekend, don't think I can get it linked back to tsdash by myself though, would need help from phil or another dev for that.
Yes, it is planned to support ADC's. But as mentioned that will take additional hardware. The Pi itself does not have any ADC capabilities.
Just recently the ms3 mini came out
https://www.diyautotune.com/product/the ... -ecu-only/
Has onboard map and baro with a pulse per meter gps you can do speed and make a custom slip calculation
