Knock_debug is sort of fixed in firmware 1.6.0. However, two hurdles present themselves in TS:
1) In order to add the sensorxx channels to the SD card logging, they must be enabled in "Generic Sensor Inputs". But, in order for the ECU to not throw an error and go into a reset loop (cycling the fuel pump repeatedly), they must be disabled. To get around this, you can enable the sensors, but NOT reset/power-cycle the ECU, then add them to SD logging channels. Then, disable the sensors before resetting the ECU.
2) TS won't log the knock_debug channels (sensor 01 through 12). I assume because they aren't enabled.
#1 at least has a path forward even if it's inelegant, but #2 means you can only get the per-cylinder retard data from SD logging, not TS. Is there a way around these two hurdles? And, if #2 can be overcome, can we limit it to just the cylinders that the tune has (instead of all 12)?
How can we log the knock_debug data in TS?
Re: How can we log the knock_debug data in TS?
You could edit the ini file.
In the file:
[YourtunerStudioProjectFolder]/projectCfg/mainController.ini
Down near the bottom of the file, you will find the [Datalog] section.
Go down to where the entries for sensor01 - sensor12 are defined.
That last parameter on each line is the Enabled parameter. If you delete it, then it will always be enabled for logging & SD Selection, even if not enabled.
In the file:
Code: Select all
entry = sensor01, { stringValue(sensor01Alias) }, float, "%.1f", { sensor01_source }
entry = sensor02, { stringValue(sensor02Alias) }, float, "%.1f", { sensor02_source }
entry = sensor03, { stringValue(sensor03Alias) }, float, "%.1f", { sensor03_source }
entry = sensor04, { stringValue(sensor04Alias) }, float, "%.1f", { sensor04_source }
entry = sensor05, { stringValue(sensor05Alias) }, float, "%.1f", { sensor05_source }
entry = sensor06, { stringValue(sensor06Alias) }, float, "%.1f", { sensor06_source }
entry = sensor07, { stringValue(sensor07Alias) }, float, "%.1f", { sensor07_source }
entry = sensor08, { stringValue(sensor08Alias) }, float, "%.1f", { sensor08_source }
entry = sensor09, { stringValue(sensor09Alias) }, float, "%.1f", { sensor09_source }
entry = sensor10, { stringValue(sensor10Alias) }, float, "%.1f", { sensor10_source }
entry = sensor11, { stringValue(sensor11Alias) }, float, "%.1f", { sensor11_source }
entry = sensor12, { stringValue(sensor12Alias) }, float, "%.1f", { sensor12_source }
Code: Select all
Awesome, thanks so much!
