Pretty self explanatory. I open a window, if I press the escape key, the current active window closes. This is pretty standard across most programs.
Thoughts?
Usability: ESC key closes active window
The man behind MS Labs
Re: Usability: ESC key closes active window
It does?
I should have elaborated; it doesn't on Linux.
Oh.. Interesting. That seems odd. I'll look into it.
And to elaborate a little further, it seems to work for some windows, but not all. For example, the comms window, it doesn't work. The project properties window, it doesn't work. But it works on the ECU Baud rate window and most others?
