New serial protocol / MS3 pre1.1 alpha codes 12+
UnaClocker
Re: New serial protocol / MS3 pre1.1 alpha codes 12+
Post by UnaClocker »
Ahh yeah.. It's using your house's electrical system to complete the ground.. Fun stuff..
Brian
'84 Dodge Rampage
Mario
Post by Mario »
Wouldn't it do the same thing in the car running off an inverter? ECU pulling ground from the USB making for lots of noise.
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
UnaClocker
Sort of. In a car that's called a ground loop. Ever wired up an amplifier and heard a whistle coming from the speakers that changes with RPM? That's a ground loop. You can't hear it with the MS, but I imagine it can cause all sorts of problems.
This new serial protocol should be robust enough to not corrupt your MSQ in that environment, at least. :)
Brian
'84 Dodge Rampage
raffa75
Post by raffa75 »
LT401Vette wrote:
HI all. i' m arriving from alpha 11 , now i have installed tuner studio 1.078 .
i have connection problem, goes of life often.
I have usb serial cable.
Have i to go to alpha 12 to solve it ?
Not necessarily. There is no reason alpha 11 should be going off line unless there is some reason in your connection. Is it going offline primarily while the engine is running? You may simply have a poorly shielded serial cable.
Alpha 12 with the new serial protocol does not fix bad serial connections, it does help insure they are detected and data is not used if corrupted.
I have never had problem with my cable. I have problem while the engine is running.
tomorrow i wil try vith 1.079
Post by jsmcortina »
A known bug with alpha 12/13.
CAN passthrough doesn't work correctly with larger data sizes. In blocks of 8 it will be fine, but if you request a full 1024k it falls over.
I know what the problem is and plan on fixing it for alpha 14.
raffa75
Post by raffa75 »
With 1.079 i have no problem
AbatelliCristian
Post by AbatelliCristian »
With alpha13 when I burn in accelerometer page, I see a msgbox "Controller error: Burn failed CRC Check. Check log for full data dump and controller page1 data".
I see thi error, but my modify is saved an then no problem...
AbatelliCristian
With alpha13 if the engine not run the connection less.....
The connection is stable and not have problem only if the vr run....
LT401Vette
Post by LT401Vette »
What version of TunerStudio are you using?
AbatelliCristian
beta version
LT401Vette
There are a lot of betas. That says very little.
It will say in the title bar.
You should be on 1.10
AbatelliCristian
My version is 1.080.
Now I see 1.11. I will Test it
AbatelliCristian
I have tested 1.11 beta version.
if vr not run and in ts I see "not synced" after a few second, ts goinig offline and I see a msgbox"Warning Communication Estabilished! However, there is a configuration error with your firmware. Check to make sure your MS3 firmware is correctly loaded. Going offline"
Is I start engine or rotate vr trimmer on jstim and I testing port in comm setting, ts going online and is all ok.
AbatelliCristian wrote:I have tested 1.11 beta version.
Please take the following test.
Go to My Documents\TunerStudioProjects and erase TunerStudioLogFile.txt
With the Megasquirt off, open TunerStudio.
On the communications menu enable "Debug Log Comm"
Power on the Megasquirt with zero rpm on the stim of car.
Wait until you get that message you mention.
Turn off the Megasquirt.
Close TunerStudio.
Attached your "TunerStudioLogFile.txt" here.
AbatelliCristian
Ok, this is my tunerstudio log....
LT401Vette
You don't by chance have your min and max TPS ADC reversed do you? The log show the same pattern as that caused.
Phil and I are looking into this.
AbatelliCristian
My tps calibration is ok. But if tps is reverse, TS going off? with previus firmware it wasn't a problem
prof315
Post by prof315 »
I noticed something wierd today on the way to work. Until my CLT reaches 170* ( warmup ends at 175) my boost duty shows 100% in spite of being set for inverted operation. As soon as CLT hits 170 it reverts to normal. But the really weird part is that boost control operation remains normal no matter what the CLT is. I apologise for the lack of msq and datalog, I currently don't have a wireless connection available for my netbook. I'll post them tonight.
Support the developers!
prof315
Post by prof315 »
Here is the datalog and msq....
